914rrr
Jul 28 2006, 08:11 PM
I need to get my 4 lug Fuchs balanced. My local mechanic actually has the 7 gram stick on weights. I want to take off the wheels and the center caps b4 I take them to him. They are NOS and dead mint, and I don't want to damage them. What is the best method, tool(s), tricks, etc. to remove them?
Thanks!
Howard
Jul 28 2006, 08:26 PM
I just use a wood dowel a little smaller than the ID of the cap and tap away. Look around your garage, bet you'll find something that works. Putting them back on is trickier.
914rrr
Jul 29 2006, 06:59 AM
Thanks. I'm looking for something a little more 'acccurate'.
I thought I remember an article using a certain size PVC pipe to remove it.
elwood-914
Jul 29 2006, 07:12 AM
I use a 2" piece of electrical PVC pipe. About a foot of it and I glued a coupling to the other end. I use the pipe to pop the cap out and I use the coupling to sit on the lip of the cap to reinstall.
Joe Bob
Jul 29 2006, 07:25 AM
Channel locks and after a 12 pack?
73Phoenix20
Jul 29 2006, 08:34 AM
QUOTE(elwood-914 @ Jul 29 2006, 05:12 AM)
That is the only way to keep the thin metal from collapsing. Make sure you clean up the inside of the center hole with some fine bronze wool b4 install... they will go back together much better that way. I have even used a dab of dish soap on the cap flange to help ease them into place.
JeffBowlsby
Jul 29 2006, 08:43 AM
I just grab them with my bare hands and wiggle them out. Takes patience but works. Do not allow the tire shop to get near them. I would be afraid of beating on them with anything they are so thin.
