QUOTE(L73 @ Jul 30 2006, 01:11 PM)
Just my luck......
I installed a new FI relay on my 75 1.8..... started just fine.
I cleaned the connectors for the air blower and now the fuel pump not working!!!
I have checked all fuses and replaced all 4 relays on the relayboard, wich is very clean. I have also replaced the fuelpump still no power to me pump..HELP ME & Thank You!!!!
huh??
there is NO relay on the board for a 1.8 L-Jet....in fact you don't need any relays at all on the board for a 1.8 L-jet 914
the correct relay is a dual relay near the battery (should be close to the resistor pack)...this dual relay controls the fuel pump and the power to the injectors when the key is "on" and the air flow meter is opened
