Well, thanks to everyone on this forum, the 914 is running again. Oil leak down to a mear drip. In fact, it seems to be comming from the remote oil filter site. Hot evening, my son and I out for a spin. Oil pressure 1-3 bars. Temp about 200. Cylinder head temp. darn forgot to hook it up. Sounds sweet though. Smooooooth.
Oh well. did not get the shifter rod hooked into the rear shifter link correct. No reverse. Well, neutral and out side and push. That got fixed first thing this morning following mass. Shifting seems fairly crisp. Kennedy clutch adjusted. A little back fire on deceleration. Hope the local police do not hear.
Well, outside, and sanding the little rust spots in the front and rear trunk compartment. Treatment with extend. sanding and painted the rear trunk before the rain started. Good thing reverse worked. Had to get it in the garage quickly.
Tomorrow the list is to sand and paint the inside of the trunk lids, and door jambs. Then it's off to the painters for a new Bright Yellow paint. The only concern I have is I wish there was someone who could look the car over and suggest that the thing is ready for continous use and reliable. I need to relocate for a few months and would like to take the care with me.
Thanks again all,
Larry
