QUOTE(Dr Evil @ Jul 31 2006, 08:14 PM)
I just thought that I should mention the other causes of issues.
Hopefully Greg will not mind the
in an effort to not create yet another transmission thread and send a mod off the ledge.
I recently experienced a "judder", sometimes violently, and read all of the technical write ups in the Haynes as well as Pelican site and knowledge base here. I ended up adjusting the clutch, which solved a related "1st and R grind". I also placed the car in the assumed position and removed and checked both tranny mounts. Both were cracked, which was the suspicion. Here is one on the passenger side, which was the worse of the two.
Based on the feedback on a search, the Wevos seem to be the best longer term solution for a street machine. I am assuming that the mounts Pelican has in their 911 section can be fit given the "ovaling" possibility. McMark had a set that looked like they did not have to get the mod to fit.
I want to drain and replace the oil. I need to get the 12mm hex tool from Pelican (spendy for the half inch drive) and follow the Dr's prescription. I have 75-90W GL5 Mobile1, but I take it that is not the correct weight, so I will make a run to the FLAPS this weekend to get the correct weight.
After the clutch adjustment, new fluid, new mounts, and I going to go the full bushing route. I also am considering to redo the reverse lock-out. Anyone have any recommendations or lessons learned on that to reduce the 2nd gear clipping?
Sorry that you are not still in San Diego, Dr. Evil. I will let you know when I am ready for some CV bolts. ( cannot believe that CV are NLA)
