Full Version: engine no.
914 dror
Hey
I’ve got a type 4 engine with this no. W0052113 vw
What engine is this - 914 ? bus ?
What size?
I’ve located another one but I don't have the no. yet so if any body has a database on type 4 engine no. of all kinds (including air cooled vanagons).
I would be very thankful.
dror
DBCooper
Should have all you need at http://tunacan.net/t4/
Reference:Crankcase will have the engine numbers.
Bleyseng
"W" code 1.7L 80hp outta a 914 or 411 from 69-71. Probably doesn't have a windage tray. Good case
Jake Raby
QUOTE(Bleyseng @ Aug 1 2006, 07:41 AM) *
Thats the case I build all my big engines from.. even my 3 liter was built on an early "W" case for many, many reasons.
914 dror
QUOTE(Jake Raby @ Aug 1 2006, 07:38 PM) *
thanks guys
what woul it take to go 2.0L with this case?
and is it cost efectiv in comper to finding good used 2.0L?
Mueller
QUOTE(914 dror @ Aug 3 2006, 11:01 AM) *
...just drop in 2.0 rods and a 2.0 crank...no mods are needed to the crank..
Al Meredith
I beleive the W case was the very early with no windage tray. Also has smaller pushrod tubes on the head side. Ever wonder why you always have extra O rings (smaller) left over after a rebuild??? The w case has no "slots" for the windage tray inside the case.
