ffranktly
Aug 1 2006, 10:06 AM
i have a 22mm Weltmeister Sway Bar and 250# springs, on a 75 2.0, and if anyone would like to swap, i need a 19mm Bar and #140 springs. thanks!... frank
and if anyone needs my Bar and Springs when i do the changeover, i can sell you mine and have them sent.
Mueller
Aug 1 2006, 11:01 AM
I can do the front bar (let me double check the dia, but I'm pretty darn sure it's the smaller of the 2)....bar only has about 100 miles on it (60 miles of that on the back of a AAA tow truck
maf914
Aug 1 2006, 11:20 AM
I don't want to sabotage Mike's offer, but...
Is a 22mm Wetmeister bar too big to run with 140# springs, assuming stock T-bars and equal size tires front and rear? Is there enough adjustment to run it soft enough?
Aaron Cox
Aug 1 2006, 12:47 PM
set on full soft it should be fine.....
ffranktly
Aug 2 2006, 10:29 AM
thanks guys, and ill wait to hear from you Mueller! does anyone need the 22mm Weltmeister?
Heeltoe914
Aug 2 2006, 10:32 AM
Is this a rear bar?
maf914
Aug 2 2006, 10:36 AM
I assume it's a front sway bar. Weltmeister makes 19mm and 22mm sway bars for the front and a 16mm bar for the rear for 914's.
ffranktly
Aug 2 2006, 12:16 PM
i haven't had the car up on a hoist and i just bought the car from joseph mills, but going by what joseph says, it is a rear 22m Weltmeister sway bar
ffranktly
Aug 2 2006, 12:20 PM
OOPs... my bad,, you are right, i read the specs again... it is the front sway bar
Mueller
Aug 3 2006, 10:19 PM
I just checked, my bar is a 19mm Welt, I won't be able to remove until this weekend.....
