I had an electrical issue show up yesterday. While I was out driving the red alternator light started flashing. I pulled over and checked the engine bay for any wiring issues. Everything looked fine. The regulator was pretty hot. Hotter that the nearby metal pieces. I shut the car off and it started right back up. THe red light was no longer flashing but I could hear the tic, tic, tic ... like it was making when it was flashing , but this time no light. Drove back to the garage and read some manuals. The manuals lead me to check to see if the belt was loose and it was.
I tightened the belt tonight and started the car. No blinking red light but still had the tic, tic .... The volt meter seemed to be registering fine. I decided to drive down the street to see how things would behave. All seemed fine except The voltmeter needle was moving sporadically a couple of times but went back to behaving normally. I shut the car off and tried to restart and had absolutely nothing. Nothing would work lights, radio, horn.... I disconnected the negative post and reconnected and tried again. The electrical system had life but it was too weak to turn over the starter. I disconnected and reconnected the negative post again and it went back to completely dead. Thought what the hell and disconnected both negative and positive terminals and then reconnected. The electrical system was back and the car started right up like there wasn't a problem, except for the tic, tic, tic....
She's in the garage now and I'm trying to decide what to try first. Change the regulator? Change a relay . I have learned alot about the electrical system already but obviously have an opportunity to learn more. I am short on time over the next couple of weeks, so any suggestions on what to try first will be greatly appreciated.
I know how much everyone likes pics so here's a pic
