[quote name='sk8kat1' date='Aug 2 2006, 02:42 PM' post='744016']
[quote name='Andyrew' post='744008' date='Aug 2 2006, 02:32 PM']
basic suby conversion... Rennegade doing all the work, or you doing all the work? 2056 is 5k...
http://www.turbo914.com/junkyard subi engine that runs perfect.. figure 500
If you go with a engine bay mount radiator.. you'll need a lot of fabrication skills. You CAN do it for 2k total or less.. some guys have done it, but they were fabricators like me.. I dont know your skills and tool avalibility.
BUT.. Keeping your suspension and everything else.. This is the rennegade list, of the max it will cost you.
$1995 BASIC SUBARU CONVERSION KIT. (not sold seperately) Includes:
- Renegade Hybrids cradle style mount
- rubber isolators
- mount plates (front)
- mount plates (rear)
- billet adapter plate
- custom 9" flywheel
- pilot bearing
- throw out bearing
- Kevlar 9" clutch disc
- stage two 9" pressure plate
- all necessary hardware
NOTE: This kit includes the high-perfomance 9" clutch upgrade already. The 9" clutch components will handle up to 400 hp and 400 foot pounds of torque...more than the 914 transaxle can typical handle!
$995 COMPLETE COOLING SYSTEM
$110 RADIATOR HOSE
$30 COOLANT HOSE ADAPTERS
$25 COOLANT TEMP SENDER: Customized VDO unit
$45 OIL PRESSURE SENDER: Customized VDO unit
$350 TURBO RELOCATION KIT (optional if turbo, you can make this)
$450 INTERCOOLER RELOCATION KIT (optional if turbo, you can make this)
$300 CUSTOM SPEED SENSOR KIT (no clue why this is on there.. but optional)
$200 CUSTOM SHIFT ROD (you can have a welder do this.. optional)
$100 TANK RETURN MODIFICATION (if you have FI, no need for this)
$100 AUGER STYLE MUFFLER (your gona need some money for exhaust stuff..)
So.. Under 4k... Thats if you have rennegade provide you with everything to do it right.
On their web page they have a LOT of other stuff in the "kit" that makes it cost much more than you need it to.
Tell me your skill level and tool avalibility... Subi is a VERY good choice.. It took me months to decide between it and a v8.
[/quote]
oops sorry didn't notice your notes next othe items.. pls ingnore that question
