QUOTE(Headrage @ Aug 2 2006, 07:55 PM)
QUOTE(TROJANMAN @ Aug 2 2006, 06:01 PM)
also, inside the pedal assembly, which would have been removed to replace the M/C,
I didn't pull the pedal assembly to swap the m/c.
Allan, been a LONG time since I messed with a stock pedal setup... the "bar" that goes into the master that the pedal pushes on - is that adjustable? I would think so... maybe that needs adjusted longer to allow the pedal to fully return
I can't remember, but it doesn't take much pedal motion to activate the switch for the lights.
Or maybe the switch just "went" and internally grounded and you just now noticed it - though that is unlikely.
