lmcchesney
Aug 3 2006, 08:55 AM
Each day a little closer and a new problem.
I was driving the car last evening and had dash lights and gauges working. I decided to turn on the head lights and off went the dash lights. Head lights off, dash lights return. All fuses intact.
I suspect, somewhere in the head lignt switch or the head lights there is a short which takes current away.
Any thoughts?
Thanks,
Larry
eg914
Aug 3 2006, 11:01 PM
It could also be creative rewiring. When I bought my car the green running light lamp came on with the headlights due to a crossed connection. Also, the Pelican site has a very good article on headlight switch repair. I also remember finding a list of continuities for the light switch connection points for each position of the switch, but I don't have a copy of it saved.
So.Cal.914
Aug 4 2006, 12:20 AM
Sometimes the reostat for dashlight brightness will goof up and cause such a
situation, use some tunerbath (you can get it at radioshack) and spray down into
the guide for the shaft. Might be easer if you drop the headlight switch first.
