QUOTE(swl @ Aug 6 2006, 05:38 AM)
Andy, I don't see how a cct breaker could 'cover up' other electrial problems. Like any other cct breaker it is there to protect you from other failures which in harnesses this old are all too common. If Jeff did not have that cct breaker what shape do you think his car would be in after that short in the fuse box? Bloody good re-engineering if you ask me - unfused ccts are an accident waiting to happen.
The only down side I can think of is that if that breaker pops your engine will die which in traffic could be scary! (think about the old 'if Microsoft built cars' ditty). Make sure that it is sized properly (including the feed wire) so it has lots of spare current when the car is under full electrical draw and it then becomes a major improvement. At least IMHO
Thanks Steve! You said what I have been thinking, and not sure how to phrase it.
I guess the other question is how to fix the underlying problem? How do you find
an intermittent short in a 30 year old car? What would you do if you had an
intermittent short? Put the car on jackstands?
it?
I was an electrical engineer, now retired. I would add something like this to a
circuit to protect it while I searched for the correct solution. I would add it to
protect the wires as they run forward to the fuse block. We are talking about 8
inches of unprotected wire now, instead of 6 feet through the firewall, up the
tunnel, and across the dashboard!
The size of the circuit breaker/thermal switch is 30 A. That is a reasonable size.
The short apparently was not beyond the fuses, since they did not blow.
So, seriously, how would YOU fix it "right"? I am not ignoring the problem. It
scared me when the car shut down. I was awfully glad I was driving a car with no
power accessories! But, I was glad the breaker was there!!! It worked perfectly.
The battery is still intact, no burned wires, no fire! I was able to get home, without
lights, but I made it! I will fix the short, when I find it. The best way is by driving
the car to shake something loose!
Jeff
