I was wondering what you guys think of the following situation? Is this something to stay away from? or is this not really a big deal? Does this need repair and how much would that cost?
I went to look at a 911 2.7 liter engine to give my 914 some extra muscle. Some work had already been done on the engine, including a valve job. Looked good at first sight However, both cylinder heads had some internal damage on one chamber each. The cylinders and pistons must have been redone cause they had no damage at all. Cylinders and case looked fine (no pulled studs).
The owner could not give much info on the engine cause he bought it as part of an entire (project) car. The work on the engine had been done by the PO he bought it from.
Back to the heads: it looks like a valve broke off and gouged the combustion chamber. Unfortunately I don't have any pictures. There was some damage that extended near the head gasket area. The gouges are pretty deep but the sealing area seems wide enough to give plenty of remaining flat area to seal. I could not see the valve seats cause the valves were installed. The head were blasted clean and new valves installed suggesting work had indeed been done.
Due to the fact that there was damage on both heads (totally neglected engine?) and that the owner wanted to sell off his project car (what's wrong with it?), I played safe and made a low bid which he didn't accept.
Any advise would be very much appreciated .... Please keep in mind that I'm not an expert at this - you probably figured that out anyway from the above.
Thanks!!!
