QUOTE(Dr. Roger @ Aug 6 2006, 01:30 PM)
nice garage paint job!
what kind of paint/prep?
Thanks Dr. I used that white primer/sealer(forget the name) the good stuff. As for the paint (sunshine yellow)I just used the old school enamel applied 4 coats and then 3 coats of clear. Wet sanded it for what appeared to be a life time and then had my neighbor buff it out. The paint looks pretty good,but the body work has some waves. I actually think I am going to do the body work over and a repaint. If I can get them into the budget I am going to replace the fiberglass flares with the steel. Using fiberglass is my biggest regret.They were concaved on the sides and took alot of reshaping to get them to look right and I should have used steel from the start since I plan to keep the car. I am in the process of the 914 loveseat project, so the car is safe from the jackstands for now.
