72914S
Oct 19 2003, 08:10 AM
Well I`ve played for a couple of days now,rebuilt engine is smokin` really! How long does it take for new rings to seat? There was an oil leak at the strainer,must have over tightened it,fixed that.The smoke out the tail pipes is very embarassing ,looks like bug fogger. Thanks, Barry
TheCabinetmaker
Oct 19 2003, 10:30 AM
Barry, not for sure, but I don't think it should smoke that much for that long. What color is the smoke?
72914S
Oct 19 2003, 10:48 AM
Kinda pale blue almost white. the engine only has about 2 hours on it, mostly on the stand.
TheCabinetmaker
Oct 19 2003, 11:05 AM
Could be your engine assembly grease. I'll check my engine rebuild book on how much and how long it should smoke. I'm assuming you followed the break in instructions. I'll bet there are those much more qualified to answer this than me on this board, so chime in guys!
J P Stein
Oct 19 2003, 11:12 AM
I'm a big fan of non-detergent 30 wt oil for seating rings.
Bleyseng
Oct 19 2003, 11:13 AM
What oil are you using????
Geoff
TheCabinetmaker
Oct 19 2003, 11:36 AM
Barry, How many miles on the motor so far? What kind of rings did you use? Chrome rings can take longer to seat. Did you do the 20 minute run in? Tell us more!!!!!!!!!!!!
72914S
Oct 19 2003, 11:49 AM
Bench time maybe 1 hour for adjustments,maybe the same after installed,8 miles from shop to house. Oil is 20/50 castrol. 20 minute what? don`t think the rings are chrome, pistons are forged aluminium. Thing is it did`nt smoke on the bench.
Bleyseng
Oct 19 2003, 11:57 AM
Cam break in period when you first start it up.
If its is the car now, drive it in 3rd gear up to 50 then decelerate to 25 then back up to 50 , do this for 5 minutes.
Then change the oil, adjust the valves, check for leaks.
Geoff
72914S
Oct 19 2003, 12:07 PM
Thanks, I`ll do that right after work today.Hope I don`t get caught (the tag is last year) the wife will give me hell if she finds out.
TheCabinetmaker
Oct 19 2003, 12:08 PM
Like Geoff said, do not hold a steady rpm on first drive. This evens pressures on both sides of the rings, and helps them seat. The 20 minute run at 2000rpm (first startup) is to get oil to all the cam and lifters and to help them "wear" in together. It didn't smoke on the bench cause it wasn't under a load.
J P Stein
Oct 19 2003, 01:05 PM
Pardon me while i scratch my haid..........
One hour run time on the bench and 8 miles on the road, right?
The cam break-in is over....good or bad.
To seat the rings, I use non- detergent oil and drive it for at least 100 miles....do a compression check..if it's good, get the crap outta there, adjust the valves, yada.
20-50 is detergent type oil. Back in the good old days I used a detergent oil in a new motor for 1500 miles and never did seat the rings.....only did that once.
72914S
Oct 19 2003, 01:31 PM
Any brand? what weight?
Bleyseng
Oct 19 2003, 01:36 PM
30wt Non- detergent any brand
72914S
Oct 19 2003, 01:44 PM
okay! A good friend of mine has a `70 Roadrunner 440 . Did you notice my side maker lights? `68 Roadrunner,nice smooth look.
J P Stein
Oct 19 2003, 03:13 PM
The only 30 wt non-det I could find was Valvoline.....at NAPA, I recall.
Tom Perso
Oct 19 2003, 03:29 PM
Dude, that cam is broke in, the motor is not going to come apart. Do the load runs like the previous people said, then go out and get on it. No crazy high RPM runs, just get out and tromp on it.
30 wt oil will help too.
Later,
Tom
