QUOTE(Bleyseng @ Aug 7 2006, 04:14 PM)
first check out the CHT as that could be bad causing richness
then check out the MPS by putting a vacuum of 15hg on it as it should hold it for bout 5 minutes.
or your flux capacitor is modulating wrong so add less fuel via the thingie.
The CHT, is it that doohicky located next to the dizzy w/ one wire coming out of it? How do i check to see if the CHT is bad? As for the MPS how do i go about putting a vacuum on the unit? Thanks Bleyseng
