QUOTE(Rand @ Aug 10 2006, 02:16 PM)
Why are you moving stuff around? If you are moving folders carelessly enough to lose your bookmarks, or you are accidently losing stuff because you don't know why it slipped a couple levels down, maybe there's a better way to manage things?
On some machines I copy the favorites to a folder under "my documents" and edit the registry to point IE there. Kind of anal, but the point is to make sure EVERYTHING I need to back up is under a single folder / tree.
Yeah, you are right. I do get careless once in a while. But I do not intentionally
move the bookmarks. It is just that I sometimes holddown th mouse I guess
after I select an item anddrag it off to parts unknown!
I donot have full use of my right (mouse) hand sometimes, as I had a stroke. I can't type too well either
! Notice the Subject: line!
As long as I can find them, I'll suffer.
Thanks!
Jeff
