J P Stein
Oct 20 2003, 01:02 PM
Some tires for your perusal. 150 minutes of track time and a drive home.
Can any suspension gurus learn anything form these?
J P Stein
Oct 20 2003, 01:03 PM
The quick brown fox jumped over the lazy bridge
Brad Roberts
Oct 20 2003, 01:05 PM
Get closer with the camera. If you have too.. shoot two pics splitting the tire down the center.
A lot of what tire engineers gather info wise from a tires is done by "feel".. but just seeing tires tell alot about it and what it has done.
B
Brad Roberts
Oct 20 2003, 01:07 PM
Just the first response from me:
It looks like the fronts are getting hotter than the rears.. Like the car might have been understeering a tad and you where compensating by more steering input.
The rears look like they where on vacation.
B
Brad Roberts
Oct 20 2003, 01:08 PM
Get some paint on the damn fenders... The primer look only works on "Rat Rods"
B
J P Stein
Oct 20 2003, 01:15 PM
Thanx, I get a lot of "compliments" on the paint job.
"Rat Rod"?....that works.
You're right about the push....just a tad... which is safe for the big track.....safe is gud for a first timer. The loud pedal would correct it, tho. The rears get hotter than the fronts at AX....didn't have a temp tester at the track.
Jeroen
Oct 20 2003, 01:16 PM
Not an expert, but it looks like you could do with a little less neg.camber
cheers,
Jeroen
seanery
Oct 20 2003, 01:17 PM
I thought that too. At first I thought they may have been slightly over inflated, but I ended thinking too much neg camber.
dakotaewing
Oct 20 2003, 01:20 PM
Are the tires in that condition on all 4 corners, or just the passenger front and rear? Your only showing the passenger side...
Thom
J P Stein
Oct 20 2003, 01:27 PM
About the same on all.
At the AXs, the fronts show even temps across the tread, the rears about 10-15 deg hotter on the inside.
There are those that say 10 deg hotter on the inside is what one wants.
Since rhe rear suspenders are coming apart, nohow, taking out a bit on negative camber dosen't bother me a bit. I just wanna be sure that is the correct thing to do.
J P Stein
Oct 20 2003, 01:44 PM
Prolly shoulda posted these first as they are the tires that get most of the work at PIR.....more right hand turns. These are the outside tires in those.
Rear
J P Stein
Oct 20 2003, 01:45 PM
Front....better focus, too
Aaron Cox
Oct 20 2003, 01:56 PM
what swaybar mount is that in that front pic?
machina
Oct 20 2003, 02:00 PM
i say you need more negative camber. Looks to me like the inside shoulder of the tires is almost virgin compared to the outside of the tire tread. This would indicate the tire is pitching out of the turn more than the negative camber can compensate for.
I can only get about -2deg front and rear on my car right now. I think -3deg would be ideal for our light cars.
Alot of race cars with radial slicks run -4deg or more of neg camber.
Check the tread with pyrometer next time if you can, that will tell you what is going on.
dr
davep
Oct 20 2003, 02:03 PM
I'll admit to not knowing anything, however, my first impression is that they appear evenly worn. They sure got very hot though. I've seen the rubber "dribbles" on slicks before; i.e. lightweight gummies.
DaveP
fiid
QUOTE(acox914 @ Oct 20 2003, 11:56 AM)
Looks like the tarret to me.
Fiid.
Aaron Cox
Oct 20 2003, 02:11 PM
someone have a link to tarret's site? can i run that mount w/ a stock bar?
Jeroen
Oct 20 2003, 02:19 PM
www.tarett.comI don't think you can run that mount with a stock bar though...
The tarett bars are bigger than 22mm because they are hollow
cheers,
Jeroen
Aaron Cox
Oct 20 2003, 02:23 PM
ouch $475!
mharrison
Oct 20 2003, 02:27 PM
My suggestion would be that you need some new tires!!!
Just kidding. I'll be following this thread to gain some knowledge on the subject.
Jeroen
Oct 20 2003, 02:32 PM
QUOTE(acox914 @ Oct 20 2003, 10:23 PM)
ouch $475!
They're not that price actually...
Compare them to the Weltscheister bars @ $300 + $100 for the adj. droplinks
Then you only have a $75 difference and the quality of the Taretts is much better
(although they're not as nice as the SmartRacing bars, but those are in another price league)
cheers,
Jeroen
campbellcj
Oct 20 2003, 02:35 PM
I know pics are deceiving (esp. of tires) but it almost looks like you're running + camber on the fronts. The shoulders look really rounded off.
I can take a pic of my Hoosiers for comparison when I get home, if I have a moment.
john rogers
Oct 20 2003, 02:36 PM
The drive home really hurt the appearance of the surface since the contact with the pavement will be different unless you drove home like you drove at the track!!!??? That's why the contact patch looks different than where the rubber has built up. What were the temps across the face of the tire? Finally, what were the tire pressures hot front and rear and were you getting any roll over onto the sidewalls? If possible, next time get some temps and pictures right in the hot pits by an assistant or even yourself.
si2t3m
Oct 20 2003, 02:52 PM
Up front: did you get some negative camber dialed out of the front??? Always tought that you have a neg camber monster (-2 or more).
Can't figure out how why the front inside seems like it's doing nothing. Tire roll? Camber?.
I got the opposite one mine this summer. 3 days (300 minutes) and a drive back, font inside looked like my
. Had alot of front camber and to much toe in!
Marc-André
seanery
Oct 20 2003, 04:10 PM
which compound of hoosiers(?) are these?
drew365
Oct 20 2003, 05:40 PM
JP; other than the one picture that shows very little wear on the inside, your tires look pretty much like my Hoosiers. It appears you didn't warm them up too much on the ride home or they would be cleaner. That's a good thing since driving Hoosiers on the street can be an expensive habit. I'm getting about 12 heat cycles from mine before they start letting me know they don't want to do this anymore.
Oct 20 2003, 06:04 PM
QUOTE(Jeroen @ Oct 20 2003, 01:32 PM)
Weltscheister
i'm not sure if a lot of people here on this board will get that subtle hint ...
Andy
ChrisReale
Oct 20 2003, 06:26 PM
I get it
In Perf. Products new catalog, they are selling a Welmeister sway bar that looks identical to the Tarret bar. What up with that?
Aaron Cox
Oct 20 2003, 06:54 PM
welt - sheister.... that's a knee slapper
(sarcastic laugh
rhodyguy
Oct 20 2003, 07:55 PM
like f.i., a black art to me. how many $ per mile?
kevin
Mueller
Oct 20 2003, 08:03 PM
I think Welt. (or whoever owns the name Welt.) has been buying other products and re-labeling them as thier own (legally of course)
Cheaper for them to do this then shell out the money for new product devolopment.
I'm just waiting for them to want to sell my needle bearing kits
I'll get Weltmiester laser etched on them if they buy enough
J P Stein
Oct 20 2003, 08:40 PM
Hoosier R3SO3s. 35 psi cold rising to 39psi hot. -2 camber both ends.
john rogers
Oct 20 2003, 09:20 PM
I'd say the pressures are too high, but then again I always say that I =guess if they are much over 28#.It appears some of the rubber is being scrubbed from the groves and is built up next to the at the side. That could be from the tires slipping from the high pressure? It's a "black art"
J P Stein
Oct 21 2003, 02:18 AM
These tires have .....humm....over 120 AX passes on em'. I run a bit less pressure at the AXs, 31-33psi and try to keep them there. I do believe that the track day was the first time they were "heat cycled".
They will last me for the first few AXs next season, me thinks......till the tire fund is built up some.
drew365
Oct 21 2003, 07:56 AM
That's the pressure Hoosier recommends, 31 - 35 cold, 39 - 41 hot. If you get the tires to 180 deg on the AX that's a heat cycle. If not I'm not sure that this tire compound is doing you much good since they feel pretty slippery to me until they heat up.
J P Stein
Oct 21 2003, 12:28 PM
You're right, they are pretty slippery on the first couple runs. I bought this compound because of the dual drivers. I wasn't sure if the "A" compound would last thru a season.
The hottest temps I saw at AX were 135 deg...inside rears....fronts were 120 all across. *With a good driver* the car was a threat for TTOD at local SCCA.
The best *I* could manage was top 20ish.
Next season I'll go with an AX compound....Hoosier or Kuhmo.....and learn to drive mo better. I also have a few suspension tweaks in mind....just to keep me busy this winter
