akellym
Aug 11 2006, 11:01 AM
Okay you guys told me how to get the 12 point bolt out on the side of the motor, GREAT! Now that it's out, how do you get the valve to slide out? It would be nice if I didn't have to turn the car on it's side and shake it!
Allan
Aug 11 2006, 11:03 AM
Magnet maybe?
eeyore
Aug 11 2006, 11:04 AM
Snap-ring / circlip pliers?
Or start the motor.
akellym
Aug 11 2006, 11:06 AM
The magnet will not pull it out..
akellym
Aug 11 2006, 11:07 AM
Thought about starting it, how much oil will come flying out?
Matt Romanowski
Aug 11 2006, 11:15 AM
You can use long nose needle nose pliers and put them in and then hold them open to pull it out. I've also used 2 screw drivers wedged against each other to get it out.
Matt
Mueller
Aug 11 2006, 11:16 AM
why mess with it if the motor is still together?
Jake Raby
Aug 11 2006, 12:37 PM
whittle down a small piece of wood to just a tad larger than the ID of the piston... Hammer it into the piston and yank it out..
do this IF a magnet doesn't work..
