A watercooled TYPE IV head would be a very easy bolt on.
After you modify the cooling tin (cylinders are still air-cooled), FI system (heads are larger, adding engine width), and everything else for an engine bay radiator system.
Much much easier than all the work in an engine conversion to Subaru.
Not if you're comparing $$$-to-HP; 914 owners tend to be CSOB's.
Liquid Cooling system could live in the engine compartment so no butchering the 914 body.
Yes, that ought to add to the ease of maintenance already encountered by most 914 owners, ESPECIALLY stock FI-equipped cars.
Allows serious turbo charging for much fun and excitement.
Again, talk to 914WRX for that application, or Jake Raby for pure T-IV. In either case, insert "CSOB" here.
Some of us have already begun to learn how to do castings and built our own aluminum foundries for not much money...
And some have abandoned the 914-4 crowd for much the the same reasons ... not enough traffic.
who needs to do "research".. superior combustion chambers on pushrod engines already exist..just copy and paste......
... on "watercooled" pushrod engines, which doesn't always translate to T-IV's.
I'm not knocking the idea, it's just that the market (and desire/enthusiasm/$$$) isn't there to recoop the investment; and that's always the bottom line.
