QUOTE(GS Guy @ Aug 2 2008, 05:56 AM)
I've noticed other cooling line connections seemed to be "press fit" into the various engine components too - such as the little lines on the throttle body heater, the cockpit heater supply connection into the water crossover on top of the engine. How are you planning to seal that turbo drain back up? Locktite?
Car is lookig great Scott!
Jeff
I have not figured out what I will use to seal the oil return. I thought about Loctite but am concerned that it would never come apart again. The oil return is not pressurized so I may just put some high temp RTV type sealant there.
Do you have an update progress thread of your project anywhere? The yahoo link you sent a while ago is down.
QUOTE(jimkelly @ Aug 2 2008, 06:21 AM)
i love the friendly one ups-man-ship on this board - just when you think you've seen the most amazing work - someone else raises the bar.
Not so much one ups-man-ship...just the advantage of knowing how other people have done things so that you can see what worked and what did not.
Made some small progress yesterday. Mounted the crank case breather tube and boost control solenoid. Both are held in place with nutserts!
Click to view attachmentProbably will not have any updates for a couple of weeks. I am getting married next weekend
and the Woodward Dream Cruise is the weekend following that.
Scott
