QUOTE(ruby914 @ Aug 3 2010, 07:55 AM)
Scott,
Nice work.
Seems you are taking a break from all the wires.
I know the feeling.
I saw what you were doing with your steering column and was inspired to follow. I will try to incorporate the instrument cluster and fabricate a new dash around it also.
I have all I need but the WRX steering wheel. I already started cutting but I am thinking it is still too long?
I see you cut it down "two more inches" so I know you have been there.
I don't have the Subaru wheel yet so I wonder if the depth between the grip and shaft is shorter on the Subaru wheel?
I measure about 7.5" outboard and 8.5" inboard from the stock 914 wheel to flat dash face. What did you finally come up with, from the dash, with the Subaru wheel?
Ruby914,
Thanks for the feedback. Glad you could find some of my experiences useful
. Although, the steering wheel adaptation is one area where my current implementation can be improved.
Currently the steering wheel sticks too far away from the dash. I do not have the stock IC installed so I measured from the back of the steering wheel to the vertical face of the dash along the steering column and the wheel is 10" away. This will be difficult to change and there is not so much room if you intend to use the Subaru plastic column cover. For me it is not much of a problem because I am short and made my pedal box position adjustable. I will have to recline my seat yet to get the perfect seating position.
There is also a problem on the back side. The shaft sticks out a bit too far and it required that I shorten parts of the intermediate shaft so that I could slide the knuckles as far over the splines as possible to avoid exceeding the max working angle of the knuckles. Before I did this I had a bit of binding. I would recommend shortening the back side even more than I did so that the shaft ends up in the same place as stock. This will require a modified/different mounting method.
Eventually I will do it again, maybe this winter. Hopefully you can refine the design so that I can copy you!
As for the wires...I have actually started to revisit them again the past couple of weeks. I have not posted any pictures because a bundle of wires looks like a bundle of wires no matter how much time I put into them. I did have a bit of a breakthrough...maybe more accurately, a reason to redo a whold bunch of work.
After much measuring and many mental iterations of wire routing, I think that I have figured out a very clean way to run the wires with a minimal amount of harness stretching. In some areas I may eventually get to shorten a few sections. If I move the main fuse box to the front where the old master cylinder reservoir was located and move the ECU to the center tunnel just in front of the rear access panel, I should be able to mount the secondary fuse box and relays under the dash or mabye under the front hood someplace. This will put all of the connectors for the Instrument cluster, switches, IG, ...etc in the proper place.
In order to do this though, it required pulling the pins for most of the wires so that I can separate the right and left engine bundles from each other and from the wires that go to the dash area. This is a very tedious process of getting the pins out of the connectors, fishing the wires out of the bundle running it back with the other wires for the same location and then getting the pin back in the correct place in the original connector. So far there have been ~10 wires that take short cuts that I have had to mark, cut and eventually extend. I have a few more hours of reorganizing before I can lay the harness in the car to confirm if my plan will work. Stay tuned.
Cheers,
Scott
