I figured out my rattle....what it was exactly, I have no idea. I gave the engine bay a quick wipe down before going to Cars and Coffee and it just stopped. Pretty sure it was one of the engine connectors vibrating. I wiped under the connectors on both sides and positioned them a bit. I thought that I had zip tied them so they could not vibrate but maybe not.
With that solved and Okteenerfest coming up I though that I would take care of a tiny pinhole leak in the radiator from a rock hit. While visiting Doug to check out Grey Matter he donated the 1.5" green stripe hose to the project so while I have the cooling system dry to fix the radiator I might as well reroute the cooling lines.
Step one, pull the raidiator and all of the cooling lines except the one in the passenger long. Then pull the Fuel tank to get access to the front of the steering rack hump.
Click to view attachment Cooling lines will come out of the lower front of the longs and enter the steering rack hump channel here:
Click to view attachmentAnd come out here:
Click to view attachmentThen go under the fuel tank and enter the radiator from below instead of above. This requires removing and plugging and exiting connections and installing new ones. I will also end up remaking most of the elbows. Plenty of work to do.
While I was aligning the car with my new stings setup I noticed that I could get half of a degree more camber on one side than the other. It sort of bothered me and after looking at it for a while I decided that my upper bushings must be off somehow. I looked into replacement bushings and really liked the Elephant Sealed Monball units. While I was ordering those I decided that I might as well put the pollybronze bushings in the front suspension also. Jez, while apart it would be a great time to install new strut inserts so I ordered a set of Bilsteins. No big deal, plenty of time before Okteenerfest.
Thankfully Stephen was nice enough to stop over Sunday morning to give me a hand with the struts, bushings and top monoball mounts. He also brought over his tube beader set for the cooling lines elbows and a box of beer. What a guy
It is still going to be pretty tight to get it back together for Okteenerfest. I have a mini vacation this weekend then I leave for a week and a half business trip in Europe on the 12th where I just happen to end up in Munich for the opening weekend of Oktoberfest. I fly back the Tuesday or Wednesday before Okteenerfest. No problem, there will plenty of time for sleep when I am dead someday.
While I am thinking of Okteenerfest, it looks like I am going to have an empty seat for the Friday Drive. If anybody with a strong back and a complete disregard for their hearing wants to experience a suby powered 914, the seat is available. Preference will go to anybody building or thinking about building one. Bribes of beer or fine liquor go a long way too!
Cheers,
Scott
