QUOTE(Bigbohr @ Oct 21 2003, 03:53 AM)
I'm looking around to upgrade the brakes, and do a 5-lug conv at the same time.
Is there a difference in performance of the suspension (front&rear) between the 911 and 914-6 options?
Is it possible to install replacement Brembo/Zimmermann rotors and bigger calipers on the 914-6 assy (in particular front)?
What would be your recommendation for this upgrade?
do you have a lot more power than stock ? do you spend a lot of time on the track ?
if that's 'no' and 'no' there is marginal benefit to be had with uprated brakes. if you can lock the wheels at the end of the straight on the tires you have, there is little more to be gained.
914.6 front suspension -is- early 911 front suspension, down to the last nut, bolt, and screw, warts and all. James has covered most of the technical issues. it's not actually the crossmember, aluminum or not, that governs torsion bar fitment, but the A-arms (914.4 and .6 are dimensionally identical, save for that spline issue) and the height adjustor block that mounts in the crossmember. if you're looking at a track application the wider array of 911-splined torsion bar sizes may be a factor - otherwise you can probably get whatever you want and probably, you'll leave it that way when you're done.
there is -nothing- about 911 rear suspension that is compatible, as James has correctly said. the hubs, stub axles, brake disks and such are one avenue to 5-lug conversion.
there is no performance difference between 911-914.6 options, because 914.6 is the same in front, and the rears and completely different. if you go -too- new in 911 parts ("Carrera") you run into Porsche's newer front suspension with radically different hub placement.
you can go as big as you want on front brakes with 911 components. you can get struts with 3,5" caliper-mounting spacing and use the finned 917 calipers from the midyear 911 Turbo. they're astonishingly expensive and very heavy. if you have to brake a 3000-lb car from 200 mph all day long, they're the hot ticket, but if you're just trying to drive a 914/4 on the street, there are better places to put your money ... as big as makes sense in that application is probably the early 911 (914.6 - same) 'M' caliper or maybe the aluminum 'S' caliper (3,5" mounting - you need to know what you want when you buy struts) or (more likely) its cast-iron 'A' equivalent. it's hard to go bigger than 914.6 rear in back (not that it's necessary) without serious fabrication - or loss of E-brake, which most of us think is -ah - suboptimal ...
recommendation? THINK about where you and the car are headed, and deal with the ENTIRE car as a package, rather than approaching each subsystem as an independent modification opportunity. are you planning a big 6 conversion, or a V8? definitely more brake. are you going to be spending a lot of time on the track (not autocross - the big stuff?) maybe more brake ... but 914's are 'quick' because they are conservation-of-momentum cars - they use their superior roadholding to carry more speed through corners than most other cars can. most slow drivers are slow because they brake too much ...
