echocanyons
Feb 28 2003, 08:02 PM
I recently picked up some calipers for my brake upgrade, I decided to go with the Boxster S setup with adapters in the front and Carrera rotors and I plan to try and modify the rear to accept the same(yeah I know about the heat issues).
The question I have is how does one tell if the Calipers are S or normal?
The part number stamps coincide with the normals on the fronts and the S on the rears
I was assured by the person I got them from that he test fitted the S pads and they fit and he was positive that they are S calipers I am tending to believe him because he is a trusted member of a west coast Pcar group.
But the part number thing is trowin me off.
Does someone have a pair of normals that they could measure?? how bout a set of 996 or S calipers??
Any other clues
Thanks
vortrex
Feb 28 2003, 08:50 PM
well...they're red. unless someone painted them, they are boxster S. unless of course you got yourself a set of big reds.
r_towle
Feb 28 2003, 08:52 PM
Yup,
Look red to me too.
R
vortrex
Feb 28 2003, 09:01 PM
I guess what I meant is the only calipers that are red in color from porsche are boxster S and big red (993-996TT, 993-996C4S). so unless someone took standard black boxster calipers and power coated them red they are boxster S. you would know the size diff if they were big reds.
EDIT: the 964 turbo's also are red, but I doubt that you have those.
r_towle
Feb 28 2003, 09:06 PM
What measurements do you need...
If I can take them on the car I have two in the garage...
Cant take off the brakes though....they are in storage....But I could measure from outside if that would help...
rich
echocanyons
Feb 28 2003, 09:49 PM
Rich,
I would like the length (top to bottom) measurement and (outer to inner) measurements.
They are painted Red I am not sure if this was done after the fact or not.
I was under the assumption that the 986S calipers were markedly bigger than the 986 normals.
My fronts are 9 1/4" length by 5 1/2" width
Thanks
Kelly
Scott
Mar 2 2003, 12:03 AM
Hate to put a plug in but can't resist. I happen to have a pair of "Big Red" rear calipers, NIB (new in box). Bought them back when I wanted to go that route and before I changed my mind. I'll make some one a great deal on them $300 for the pair. I also happen to have the larger Mercedes 21mm master with the longer push rod and reservoir tube (also NIB) for Low $$$ too. Let me know if anyone is interested.
