jake, have you tried or experimented with any of the racing plugs.
Yes, not impressed. I have had plugs sent to me from most every manufacturer, none have been worth their cost as gains were sometimes not measurable on my dyno. Some plugs I have gotten second hand from some local NASCAR teams that have ran them in their engines and some they had not- still no gains in anything on our engines.
I remain open minded and willing to try anything, BUT to this point the Bosch copper plugs are in all of my cars but one, the Pinzgauer because it uses a plug that takes a screwed on type spark plug wire to be waterproof..
Is this the same idea behind yours? Do you have any pictures of yours? I would be interested if it is the same idea but executed in a better way.
This mayterial is the best phonelic type material that Len found. I have ,measured carb temps to be 40 degrees lower with this gasket used! Thats how well they work!! ALL my engines get them these days and the CNC heads require them.
Pictures of the LE 220 heads will be up later today.
4th dimension Radio is our new internet radio show that is all about type 4 engines, its co-hosted by yours truly and the first episode airs tomorrow at 8 PM EST. It can be downl;oaded at www.aircooledtechnology.com/radio every week. We are spilling the beans on so many new things that will only be talked about on the radio show!!!
