I need a little help with routing/attaching fuel lines on my '75 2.0.
I had the tank out as well as the fuel pump. Now am installing these items. There are two spigots at the bottom of the fuel tank, and two steel tubes and a small plastic (I believe a vacuum line for the window washer system) coming thru the front lower firewall.
The way I read the manual diagram is one outlet from the fuel tank goes to the fuel filter and then to the fuel pump. From the fuel pump outlet then to one of the steel tubes going to the back of the car - from the back of the car into the fuel loop going to the pressure regulator, and then the fuel injector fuel line loop is completed by going back thru the car to the front - but then where does that fuel line go - back into the other fuel tank spigot? The fuel pump just has one inlet and one outlet.
Also - I have read the dangers of the plastic fuel lines going thru the center tunnel - but it appears mine are steel - so was there a change made by Porsche from plastic to steel and what year model was the change made? Just want to be sure I don't have to worry about this problem.
Thank you for your help!
