David_S
Aug 16 2006, 05:23 PM
I am trying to install some of my wiring harness back into my car. Haynes diagram for a 73 shows a brown & brown/white going to the master cylinder switch. I have both wires, but just one terminal on the switch. Pulled the master cylinder out of the 76 parts car, and just one terminal on it also. I am guessing that the brown/white wire goes on the switch. If so, where does the brown wire hook up, or is it "just there" ?? Been too long since I pulled it apart !!!!
SLITS
Aug 16 2006, 05:31 PM
Brown w/ white goes to the switch. Brown goes to ground on the body. With a single pole switch, it would appear that the ground is thru the switch on the MC and therefore, the brown wire is not needed.
David_S
Aug 16 2006, 05:52 PM
OK ...that is what I was thinking. So .....I just need to ignore the brown wire....right ???
SLITS
Aug 16 2006, 05:59 PM
That would be my thinking.
David_S
Aug 16 2006, 06:01 PM
Ok ...thanks Slits !!!!! One more headach out of the way in this clusterfuch of wires !!!!
