QUOTE(Mueller @ Aug 17 2006, 02:30 PM)
some people claim a 7" rim with a 23mm offset works on stock rear fender, I say baloney since it's never worked for me, I've always had to roll the lip and/or pull the fender out a bit...
I am running a 7" rim with a 35mm offset which fits under the stock rear fender, there really isn't any more room to go inboard towards the trunk since you'll hit the trunk wall and the trailing arm...
36mm, the offset of the 6" common rims, is very good for centering in the
rear fender.
At least for me, I can fit the 40mm offset 7x16 boxster rims without hitting the
inner fender, with ~2 degrees neg camber even.
Mike, what rim do you have? ( 7" 35mm offset)
