QUOTE(wbergtho @ Aug 19 2006, 08:16 AM)
I'm actually surprised to see the guide tube looking as good as it does. I do see some wear though. How long does it take to drop your trans now? I assume you have had it on/off a few times...like I have.
Yes I have had it out countless times, I have air and it takes about 30 minutes. I don't rush it. Installing it is a different story, as you know seating the input shaft / clutch is a bit more detailed.
The tube has more wear on the bottom side, thats not the norm considering gravity but I have a spring pulling up on the outer clutch arm to help carry the extra weight of the outer assembly. Its hard to see but there is a grove acting like a small curb and the wear marks travel to the end of the flange. I am not sure what happened but it looks like the T/O bottomed out with hydraulic volume to spare. I must have pushed the clutch 1/4 inch or so further and snapped the flanges. When I first noticed something I depressed the clutch and herd a snap, kept the pedal down and left off in first gear, depressed the clutch again and herd another snap. Then there was no clutch pedal effort anymore/ pedal just sat on the floor / not good news in traffic. I got lucky and rolled into a parking lot.
The fact WD-40 helped with pedal effort says there was a lot of friction in the mechanism. I am going to make sure everything is new and lined up along with having the correct grease. Waiting for parts now. It's likely going to cost around 500 bucks to get it going again. Sh*t happens!
Since I have it out you know I am trying to cook up a different clutch pedal master system(still trying to come up with something new). I keep looking at how we use electric motors, IE windows. The idea of using an electric / linear actuator seems possible. You couldn't or its not likely that a foot control would work, it seems a finger control would be essayer to modulate. Well shoot I keep trying to get the idea going...................................................................................................................................................
Ha Ha Ha
