I got the rear sway seperated from the shock bolts using a big wrench and 'popping' them off like a pickle fork would do. What is the correct way to reattach them?
Thanks.
-Aaron
Aug 17 2006, 07:01 PM
QUOTE(yeahmag @ Aug 17 2006, 05:54 PM)
same ... big pipe-wrench werks just fine ... Andy
yeahmag
Aug 17 2006, 07:04 PM
Just beat them back on? I don't have to do anything like remove the bushing. put it on the shock bolt, then slide the rod over top?
-Aaron
Aug 17 2006, 07:08 PM
QUOTE(yeahmag @ Aug 17 2006, 06:04 PM)
don't beat 'em, bushings in the droplink where they belong, put on the round bolt-end, use very large pipe-wrench to press droplink onto the bolt-end ...
done ... Andy
yeahmag
Aug 17 2006, 07:17 PM
I can't quite picture using a pipe wrench... I have a decent sized one that I used for the struts, I'll put it up there and see if anything makes sense.
In a pinch could I use a C-Clamp to squeeze them back together?
Thanks.
Aug 17 2006, 07:21 PM
QUOTE(yeahmag @ Aug 17 2006, 06:17 PM)
whatever floats your boat, c-clamp will work just fine as well ... Andy
Trekkor
Aug 17 2006, 07:38 PM
I use ginormous channel locks.
KT
Aaron Cox
Aug 17 2006, 10:21 PM
channel locks indeed aaron!
