Last night I changed the oil to a break in oil (non detergent 30 weight) ran the engine to warm it up,the oil light stayed on the whole time?( 2-3 min. ) shut it down covered it up went to the house for the night. This morning went out to check for leaks,(had a small leak before the oil change) there was about 3 Qts of oil onder the car! no leaks at the filter,no leaks at the strainer! appears to be from the oil pump or the cooler. can these parts be removed with out dropping the engine? It was said I might have blown the cooler with the H.D. oil pump. Sure don`t want to drop the engine again so soon.
