Got my car finally started,(didn't know that if the cht wire disconnects your car isn't starting or will die if running), on freeway I turn on the headights, just to check.
Turning them off resulted in the left headlight closing and opening i.e. winking, right side stays down. Seems I have read about this symptom somewhere?
When I signaled for a left turn it stayed down- then worked correctly, both up and down when switched off. Short somewhere?
BTW my high beam flasher is not working, I just got a replacement, I'll put it in and try again.
