https://www.gex.com/mainframe.htm
some of their prices seem reasonable.
Late Type II & IV (Bus, Van)
1972-1983
& 914 Porsche 1970-1976
Long Block Engines
All GEX Long Block engines are Hot Run Tested. This means that we temporarily install carburetion and other accessories to actually fire them up to run our
914 Porsche
Part # Description Price Core
GX 10919 1800 cc, 70-72, fuel injected, breather pipes, with sensor
Price Core
$ 1,499.00 $ 300.00
GX 10920 1800 cc, 73-74, fuel injected, with sensor only
Price Core
1,499.00 300.00
GX 10927 2.0 liter, 74-76, fuel injected, breather pipes, with sensor
Price Core
1,899.00 500.00
GX 10928 2.0 liter, 74-76, fuel injected, with sensor, 2 holes each head
Price Core
1,899.00 500.00
All GEX Premium stock engines are covered by our nationwide, no hassle 12 months or 12,000 mile PARTS and LABOR warranty. See warranty card for details. An optional 36 month or 36,000 mile warranty is also available on all stock engines listed here for an additional $199.00.
SLS/PR00004 36 Month or 36,000 Mile Warranty $ 199.00
To make that engine run cooler, smoother and longer, we recommend that you consider the following options:
Electronic Balancing - For longer life and a smooth running engine.
Counterweighted Crankshaft - Allows engine to run smoother and ultimately to last longer.
Maxi Oil Pump - Closer tolerances than a stock pump, provides added volume and increased oil pressure during low speed operation.
Installation Kit - Now is the time to replace those worn out or missing accessories.
The same 12 month or 12,000 mile warranty applies to engines with these options.
Maxi Oil Pump
SLS/LBR/BAL Electronic Balancing $ 169.00
CR 039105101/CXUP Counterweighted Crankshaft (upgrade) 199.00
OP 1829 Maxi Oil Pump 93.50
IK 11210 Installation Kit Type II, 72-73 399.00
IK 11215 Installation Kit Type II, 74-75 399.00
IK 11228 Installation Kit Type II, 76-79 399.00
IK 11228V Installation Kit Type II, 80-83, Van 439.00
These engines do not include flywheel and are available only with rebuilt heads. Also see the GEX POWER MASTER engines and options on the next page.
