Back story:
Found this 1987 Chevy G20 van conversion (well, my wife spotted it) for sale. Wouldn't pass smog, had a bad miss (and the rumble in question). The miss felt to me like it still had good compression and the engine seemed to be pulling strong considering it was running on 7 and had 180k miles. I figured the rumble was because of the miss. I went with my gut instinct and made a lowball offer which was accepted.
Well I did a tune up (plugs, cap, rotor, 02 sensor, thermostat) and put the spark plug wire back on that had fallen off (heh) and now it pass smog with below average emissions, and runs pretty good. Unfortunately the rumble is still there.
The rumble seems to shake the whole van, and is even (not a miss). It makes everything rattle, and it sort of reverberates with a droning quality. It only does it while stopped and in drive/reverse. As soon as you start going, it goes away and everything is smooth as butter. The transmission shifts fine (although sooner than I'd like, not sure if that's adjustable) and according to the receipts that came with it, the trans was rebuilt a couple years back, for big $$$. I thought it might be engine mounts, but I did the "step on the brake and gun it in drive and reverse while watching the engine" thing and it hardly moves. The engine is a 350 with TBI. I also wouldn't mind hearing any cheap ideas for getting a little more power out of it.. It's rated at pretty low HP for a 350. Maybe a distributor with a better advance curve? Has to be smog legal though.
Anyone have any ideas what it might be?
BTW, the wheels are crap (oval holes for multiple bolt patterns, and they're starting to rust), so if anyone has some 5 x 5" bolt pattern wheels for sale cheap, I'm interested).
