QUOTE(bmunday @ Aug 25 2006, 08:32 AM)
Can anyone post a picture of the correct or propper mounting location?
there is no correct and proper mounting location for a carb fuel pump as no 914 ever delievered to the US came with carbs.
I guess I could have phrased the question better, best location for the fuel pump.
having said that, i reused the stock mounting location in the drivers side rear for my rotary carb fuel pump and mounted it with rubber insulators.
I will give the insulator a shot.
and yes, the tapping noise is usually when they run dry. got gas?
Andy
Gas I got....
When the fuel pump is running, should it be a steady flow, or is it pulsating, as if you are turning off and on a faucet?
