QUOTE(freezing14 @ Aug 25 2006, 11:35 AM)
for a -6 rebuilt , wanna do transparent upgrade,, the bore is the same for the 2 , stroke come from the crank but will they fit with a 2,0 case with a 2.0 crank
thanks
2.2 piston/cylinders will fit. Same stroke. 2.4 pistons have a far different pin location, and will not work with a 2 litre crank and rods. Furthermore, it you have 901 cams, 2.2T pistons won't work, either. The Cap'n
