My 911 tach for my 3.2 is not showing revs correctly. It does rev slowly to about 2,000 rpm when the engine is obviously reving much higher. Do I need a new tach or is there some sort of debug procedure I can check. One question I have is: does the tach unit body itself have to be grounded to the dash to work or just the ground connection to the back of the unit itself?
It worked this spring when I drove it last
