brer
Aug 28 2006, 03:38 PM
I'm playing with a new program and need the flow numbers for the stock 1.7, 1.8 and 2.0L heads.
Any help would be greatly appreciated.
b.
HAM Inc
Aug 28 2006, 05:03 PM
The 1.7's intakes flow around 155CFM @ .500"lift and 28" of vaccum. The ex.around 96CFM. Average flow for the two ports is around 112 and 78.
The 1.8's intakes flow around 161CFM @ .500"lift, the exhaust around 110.
Average flow for the two ports is around 112 and 85.
The 2.0 914 heads intakes flow around 177 @ .500"lift, the exhaust around 135. The average flow for the two ports is around 132 and 99.
Aside from the increased flow, the 2.0 914 heads also benefit greatly from the improved sparkplug angle, to the tune of 10-12% more torgue than an engine equipped with heads offering the same port shapes and the same flow values, but with the side plug angle of the 1.7's and 1.8's.
1.8 ports can be improved to the 2.0 specs without a whole lot of trouble, but the plug angle is still an issue. Ofcourse that too can be moved.
1.7 intake ports can not be easily improved to 2.0 port specs, though the ex. ports can. That makes these heads good candidates for turbo engines, though the plugs should (IMHO) be relocated to the 2.0 914 postion, for more torque and reliability.
McMark
Aug 28 2006, 05:10 PM
BAM!!
Thanks LEN!!
You
must have that saved somewhere for easy posting.
Jake Raby
Aug 28 2006, 06:10 PM
Watch those programs. I see people all the time that make HUGE mistakes when allowing software to do all their thinking.
I use programs as well, but have only found one that gives accurate results, it even has its drawbacks- but is very accurate.
brer
Aug 31 2006, 04:26 PM
Thanks for the warning.
Its more for educational purposes really.
When I want to build a big engine i'll go for a proven recipe.
Mueller
Aug 31 2006, 05:20 PM
