krazykonrad
Sep 3 2006, 11:09 AM
Is it possible or even advisable to pull the heads off with the engine still in the car?
Thanks!
Konrad 72/4
mihai914
Sep 3 2006, 11:23 AM
Possible maybe, advisable NO. It's far simpler and quicker to just pull the whole engine/transmission combo, it's easy to do and there is an article on Pelican that you can follow.
Allan
Sep 3 2006, 11:45 AM
I don't think it's possible.
pete-stevers
Sep 3 2006, 12:03 PM
it might be possible....so you want to be the first?
more work that way.....way easier to drop the motor /tranny.....
type47
Sep 3 2006, 12:31 PM
very much worth the effort to drop the engine first, not saying you can't pull heads with engine in car, but look at all the stuff you need access to, to remove the heads. in my opinion, it would save time to drop the engine first. save time and agony trying to get to all the things required to be removed before removing the heads IF they don't hit the side of the engine bay before they clear the head studs!
need to remove or at least disconnect from heads:
intake runners
rocker arms
valve covers
engine cooling tin
alternator (?)
(all i can think of at the moment)
krazykonrad
Sep 3 2006, 12:39 PM
Thanks! An engine drop it is!
Konrad
ClayPerrine
Sep 4 2006, 12:06 AM
Actually it can be done, and I have done it. I had to pull one of theheads on Betty's car years ago to fix a broken exhaust stud, and I didnt' have a garage, just a carport and a shed. The motor and tranny combo wouldn't fit in the shed, so I just removed all the necessary components, and dropped down one side of the motor low enough to clear the suspension. It worked, but I would rather pull the motor to do it.
Its no big deal, just ubolt the motor mounts in the front and drop it down just enough to do the job. If ya have to work on your back it may be a PITA.
Gluck!
alpha434
Sep 4 2006, 07:32 AM
Way to give him the run around. Come on, guys. Always opt to exert the least energy first, and then apply more if more is needed. If he's got the engine lowered in the car, then all it's going to take is another 2 bolts out and another drop of the jack to get it the rest of the way. But if he can do the job "in-car," it'll be half as much work to put it back in.
Two more bolts latter, then the wires, then the ground cables, then....
Less is more, more or less. Me lazy.
SLITS
Sep 4 2006, 09:05 AM
4 bolts for the tranny mounts.
1 nut for the ground strap.
8 bolts for the CVs
Two fuel line disconnect
Throttle cable disconnect
Clutch cable disconnect
Speedo cable disconnect
Muffler removal (or at least rear valence)
Plus...how to break the rear tranny mounts by dropping the engine to far and stressing the ears.
