QUOTE(stock93 @ Oct 26 2003, 02:39 PM)
Does anyone have a how to on tapping the oil galleys? I know how to tap threads I just dont know which ones to tap or should I just tap all of them?
John
I started (this year) to pull/tap cases after rebuilding two customers’ engines (last year) and have to do R&R's because of leaking plugs. I was horrified at the amount of crap that came out of the galleys. On one of my own cases I bead blasted it, then hot tanked/washed it 3 times. When I pulled the plugs all kinds of glass beads fell out.
5- 3/8" NPT (national pipe thread)
5- 1/4" NPT
1- 1/8" NPT
3 of the 3/8"NPT are behind the flywheel, one 1/4" is under/between 3/4 cylinders (this one I sometimes skip as you can clean this galley and it rarely leaks), the 1/8" is right beside the nose seal and the rest are around the cooler/filter area.
I use the steel (allan/hex) plugs, I've tried the Al and brass plugs. Some will argue that the Al plugs are better because of the expansion rate, but the steel ones can be cranked in way tighter. Use some locktite, mine never leak.
