Mueller
Oct 26 2003, 11:10 AM
I know the oil squirters are installed in the crank mains on the block, but how do they get thier oil?
Are the crank bearings modified with a small hole to feed oil to the squirters?
Brad Roberts
Oct 26 2003, 11:11 AM
A passage is drilled down into the main oil feed for the bearing (the bearings have nothing to do with this).
Dont even think about it on your 4 cyl.
B
Charles Deutsch
Oct 26 2003, 12:09 PM
Here's some info that might help you.
Charles Deutsch
Oct 26 2003, 12:10 PM
Charles Deutsch
Charles Deutsch
Oct 26 2003, 12:11 PM
redshift
Oct 26 2003, 12:13 PM
Welp, there you go.
I am thinking blue billet squirters.
M
Brad Roberts
Do you think you could scan a 911 ENGINE and show him how the oil passage work ??
How many scanner have you gone thru ??
B
Charles Deutsch
Oct 26 2003, 12:16 PM
QUOTE(Brad Roberts @ Oct 26 2003, 10:13 AM)
B
My "reference library" contains more general auto info. I have no 911 engine stuff.
Brad Roberts
Oct 26 2003, 12:31 PM
Doh !!.. I seriously wanted you to post a 911 engine to show him how the squirter passages worked.
B
TimT
Oct 26 2003, 02:53 PM
OK heres a scan from BAs book.
If you are going to have your case modifed for squirters, get the 964 squiters, rather than the 911 ones. The 964 units spray more oil.
Also whats the best way to scan from a book? grayscale? photo?
Brad Roberts
Oct 27 2003, 12:21 AM
Thanks Tim. This is EXACTLY what I wanted to show.
GreyScale is perfect. If you scan in color the file will be too large.
B
