rmital
Sep 4 2006, 06:51 PM
How do you detach the throttle positioning switch from the 2.0L throttle body?? The two screws on the right and left are just for postioning....don't want to f'it up.
Remove the screws and slide it off lifting on the metal tabs the screws go thru. The center part is just a snug fit on the "D" shaped shaft.
rmital
Sep 4 2006, 07:39 PM
thanks Ed....that was easy.
...it was definitely snug enough that I didn't want to force it off.
