QUOTE(ClayPerrine @ Sep 5 2006, 01:15 AM)
BTDT....
The problem with using MSD on the L-jet is the signal that goes back to the FI from the coil. THe MSD confuses the computer, making it think that the engine is running way too high of RPM. The solution is to use the tach output of the MSD to run the FI and the tach.
Other than that, it works fine.
thanks Clay, I had you in mind when I posted the question
the multispark of the MSD is what worried me, I forgot about the tach output....
Britt, no package yet, just doing a little bit of planning
Geoff, I too like the L-jet, I've had it on a stock 1.8, a 1911 and a 2.0 with higher compression and thought it was a great system. Only problems I had was with the dual relay, bought a new one and fixed the problem.
I'm keeping my Link FI for a future engine build....
