QUOTE(Series9 @ Sep 5 2006, 08:08 PM)
None of this has to do with engine size. It has to do with the pump(s).
A /4 has one pump: A pressure pump which must supply both pressure to the engine and flow to the cooler. I would be reluctant to run lines larger than -10 because the external cooler becomes part of the overall pressure system and a /4 pump is only capable of so much.
To review: -12 lines are used on a /6 to keep pressures DOWN, -10 lines are used on a /4 to keep pressures UP. They are completely different arrangements.
I agree that the T4 has a single pump, but I'm not so sure about the line size/pressure relationship.
The T4 oil pump pressurizes the oil and sends it to the oil filter, the stock oil cooler, and then to the engine. The oil leaves the pump at its highest pressure. As it flows through the various components friction causes a drop in pressure and the end pressure at the crank, lifters, etc., will be slightly less than pump discharge.
When an external cooler, lines and fitings are added, typically via a sandwich plate at the oil filter, additional flow resistance is being added. Flow through the lines and cooler means additional friction and pressure drop. This pressure drop is then added to the stock component pressure drop to determine final pressure.
Pressure drop through the lines and fittings is directly relateded to diameter. The smaller the lines, the higher the flow velocity is, the greater the friction, the greater the pressure loss. It's unavoidable. Larger lines mean lower velocity, lower friction and less pressure loss.
With a T4, if you want to keep the oil pressure up, I think you should go with larger lines and fittings, say -12, especially if you're running them to a front mounted cooler. And this applies even if the sandwich plate has smaller -10 fittings. These smaller fittings may be a restriction, but it's not necessary to add another 25 to 30 feet of -10 line and its restriction to the system.
Having said all of that, I am still unsure how well a T4 oil pump handles an exterior front mounted cooler.
