Darn it Mark, you beat me to it.... on the road and working late, I didn't get a chance to follow up on this one...
interesting reading can be found here:
http://www.914world.com/bbs2/index.php?show...c=53733&hl=I am still tuneing, as often as I get home, but the base tune would start and drive the car. If you are using the factory intake/fuel system, your tune may be easier still, as you will probably have a more stable vaccume signal, and more linear airflow. Boy, when those ITB's open up, you need to dump in the fuel to keep up.
If you are going with fuel only, retain the stock dizzy or upgrade (eventually) to a Mallory. I've never used one myself, but if others on the board swear by then, rather than at them, they must be good. I had strongly considered going this route, but decided to jump in the deep end rather than splash around the shore.
If you are going a little more all out, and getting the crank fired ignition, get ready to drop the motor and fabricate a little. It really wasn't all that hard. I'm not sure, but quite certain, that if you get the fuel only system, you can't just add the coil pac and upgrade to the crank fired ignition at a later date- I think you have to upgrade the whole ECU, but Mark would know for sure on that.
Absolutely budget $$$ for the WMS wideband system. It integrates with the SDS and makes the tuneing SO much smoother. Just read the SDS website, and down load the manuals. Read them often. The more you read, the more you know, the more familier you get with the system, the less scary it becomes.
-Would I do it again? For sure, the education along the way has been great, and I find the work/puttering around relaxing.
-Was it plug and play? C'mon, is
anything really that easy? But this was close.
-Is the car faster? Don't know just yet. My combo of ITB intake/crank fire ignition/"euro" longblock/stock cam/SDS is, I think, the first of its kind. Jake may have done some combos that are similar, but he ain't talkin... When the dyno is done, results will be posted. When that will be is anyones guess.-
