Check this out for SDS install info:
http://www.914world.com/bbs2/index.php?show...c=53733&hl=You could use your "used" 2.3 ford turbo system on your 914, BUT- you'll need a 1 bar MPS (manifold pressure sensor) for a non-turbo engine. If you use the turbo MPS, (likely a 2 bar, maybe a 3bar) you'll be cutting down the # of tuning locations availible, as the turbo MPS, and the SDS brain, will be looking for, say, 15 tuning locations with no boost, and 15 locations for boost up to 2bar, for a total of 30 locations. If you are running a non turbo engine, you only have, in this example, 15 tuning locations to adjust manifold pressure based fuel enrichment. You have lost 50% of your flexability in tuning the engine. Using a 1bar MPS, you would have 30, or two times as much resolution. If this "used" system is a 3bar system, in this same example, you'd have 10 locations up to 1bar, 10 more locations from 1bar to 2bar, and 10 more locations from 2bar to 3bar. You'd be missing out on 2/3 of the range of adjustment the system SHOULD be providing, but can't, because it is not matched up to your engine. You CAN buy a 1bar map sensor, and get some help from the SDS guys to re-scale the MPS tuning points on the ecu, and make this work on your 914 application.
When I spoke with the SDS guys about using the system 4-F as fuel only, they were not in favor of trying this, as the crank position sensor provided info for the ignition as well as the fuel. Best to email Ross or Barry direct at SDS to get that answer in greater detail, as my question to them was a yr ago or so, and I forget the details of their answer.
Injectors: Most newer style injectors will use the fuel rail as a mounting point for the top of the injector, as well as a means to secure it to the intake manifold. Add to this the non-standard spacing of the injectors on a factory 914 intake, and you'll need to do some neat fabrication. Not impossible, but if your factory injectors are fine, why not just have then serviced, cleaned, flow tested, and stick with those. This is probably cheeper than new injectors and figuring out how to mount/feed them.
The WIDEBAND 02 sensor is a much needed tool to get it right. Just choke up the $$$ for the WMS system as offered on the SDS page. I'd also check with Ross or Berry on having your "used" system re-flashed to include the 02 logging that the current systems can do. It just gets easier having all the info in one place, rather than having to look at the SDS controller and a separate wideband display, make mental notes on whats up, remember what you wanted to change, pull over, change it, and good luck... Having all the info in one spot, and a trusted driver, makes the tuning go much better.
