QUOTE(si2t3m @ Oct 28 2003, 12:46 PM)
What RC car are you using for the 914 body?
TIA
I used a 1/28 scale Kyosho Mini-Z chassis to mount the 914 body. I did have to lengthen the wheelbase by about 1/2 inch to 4 inches. I did that by making a new, longer H plate (very easy). Then I attached the body with velcro. The body isn't attached all that well (it will flly off if you run into something), but I didn't want to drill holes in the body to mount it - and I won't be using that car to bash around.
Kyosho mini-z's run about $100-$120 and include all radio gear and electronics. They are very nice cars with full porportional steering and throttle.
Kyosho Mini-z from Tower HobbiesYou can get knock-offs of the mini-z, which are exactly the same car. Most people report no problems with them, although quality control doesn't seem to be quite as good as Kyosho. They are LXX ScaleZ cars, and the only place I know of to get them is direct from Hong Kong. Cost is about $45 including shipping.
ToyEast LXX ScaleZIf you want the bare minimum to mount a car on, you can get HeiPao mini-z clones on e-bay for about $20-$25 shipped (just search for mini-z, anything that does not specify Kyosho brand is a knock off). These do not have porportional steering and throttle (on/off steering, on/off throttle). But they should be fine for mounting the body on (still must extend the wheelbase and figure out body mounting scheme just like the other cars). They just won't be all that great for driving around. One thing about the HeiPao clones - the motor *MAY* sit too high on these cars for the rear of the body to sit all the way down properly. On the Mini-z and LXX cars, you can rotate the motor to sit behind the rear axle instead of over the rear axle, which reduces the height needed. The HeiPao cars cannot do this.
There are a variety of other 1/24 scale r/c cars that you could use as well. Most important thing is that they be able to accomodate a 4" wheelbase. Width is also important, and you want something around 65mm width for the stock bodies, and something closer to probably 75mm for the GT bodies.
Hope that covers it.
Demick
