bd1308
Sep 12 2006, 09:35 PM
We have been getting hit HARD by rain, and i havent done much long distance driving lately.
Now, upon startup I get a kinda sound like 'i need some oil here' or something liek that.
The engine sounds fine, and the oil level is really good. and alternators do funky things, so maybe its brushes or something like that.
Or what could it be?
I've been taking real good care of this engine, as soon as it stops raining i'll do another oil change.
b
bd1308
Sep 12 2006, 09:39 PM
it doesnt sound engine related at all...
mihai914
Sep 12 2006, 09:40 PM
Rubber squeaks too. Did you check the belt?
Eric_Shea
Sep 12 2006, 09:43 PM
Sure... they can squeak. Bushings may be going. The wife's E320 alternator whines. Sounds like a fire engine. I kinda like it... LOL
drive-ability
Sep 12 2006, 09:58 PM
Start the engine cold and if it's got a marginally loose alternator belt combined with a low battery charge (engine may crank and start fine) will make the load on the belt higher. The loose belt will slip a bit normally just a few times, then quit and work quietly. Oil will just make it worse, check the condition of the belt etc. A moist environment can add to the slippage.
bd1308
Sep 12 2006, 10:05 PM
Man its been POURING buckets for three straight days. I bet when it clears up it'll stop squeaking. Didnt sound like a Chrysler sweak (sk
My 914 leaks like a WWII U-Boat.
I'm driving and i look over to see drip drip drip drip drip drip from the passenger side 'vent window' where my targa seal (the one nobody can find) is just shot.
type47
Sep 13 2006, 06:19 AM
QUOTE(bd1308 @ Sep 12 2006, 08:05 PM)
in the 914 boutique on Pelican Parts, you can buy the 914 wet suit
Joe Ricard
Sep 13 2006, 06:25 AM
Yea you should oil anything that squeaks. Belts too.
HA HAHAHAHAHAHAH.
Or put a new belt on for 5 bucks from FLAPS.
SLITS
Sep 13 2006, 06:33 AM
Or buy a can / stick of belt dressing, apply it and see if the squeak goes away.
Personally, I like cherry flavor.......
bd1308
Sep 13 2006, 07:19 AM
Rain stopped, not as wet now, I can actually wear good clothes, and....
no squeak.
I'll get a new belt.
b
jr91472
Sep 13 2006, 08:12 AM
Alternators have bearings that can go bad too. But in my experience its more of a rattle than a squeak.
bd1308
Sep 13 2006, 11:20 AM
Well it was a rattle sound too, kind a squeaky and rattly.
sorry i didnt mentione that before but its gone now
tommy914
Sep 13 2006, 03:02 PM
You should change the alternator oil every 30,000 miles.
brp914
Sep 13 2006, 07:22 PM
no laffing matter. my alt was squeaky. I ignored it until one day the alt bearings froze causing a chunk of the fan housing to be ripped out at the lower alt mount. Tried to fill the missing chunk with epoxy - didn't work. Finally had to take engine out and replace fan housing - yay.
bd1308
Sep 13 2006, 07:48 PM
wow...
how long did it take?
its been dry today and it didnt make one squeak...
I'll change the belt and see what happens
brp914
Sep 13 2006, 08:17 PM
fixed it in a wknd, but this was years ago, when junk yards and 914's were more plentiful. nowadays this could put you out of commission for weeks. if you take your belt off, spin the alt and see if its still squeaky.
bd1308
Sep 13 2006, 08:50 PM
I have about three alternators I can use
