shaggy
Sep 12 2006, 09:43 PM
how specific is the spring in the dizzy shaft?
i had it 10 minutes ago!
i just took it out of the carb cleaner and had whiped it off and carried it into my room.
i carried all the dizzy parts into me room for reassembly and now i cant find it anywhere!
i have retraced my steps with a flash light to no avail.
so...
is it a home depot part?
-shaggy
shaggy
Sep 13 2006, 08:49 PM
bd1308
Sep 13 2006, 09:05 PM
IN the dizzy shaft, or you mean the one thats connected to the weights?
Did you get that pin out? I told you it would be a PITA
TravisNeff
Sep 13 2006, 09:13 PM
The only springs in there are for the advance mechanism. I hate to say it, you are screwed. I had the same issue with one of my distributors, I could not find anyone who carried them, or ever knew of a replacement part available. You can try to get another distributor and steal a spring form it, but you probably wantt the same model number dizzy to pull from - I am assuming the springs are different from dizzy to dizzy (although it might not be all that much).
bd1308
Sep 13 2006, 09:24 PM
Jim, what part number is your dizzy?
b
shaggy
Sep 13 2006, 09:59 PM
im talking about the spring on the top of the distributer drive shaft, the little shaft that runs off of the brass gear on the crank....
-jim
bd1308
Sep 13 2006, 10:22 PM
OH
hmm
I dunno about that spring...doesnt seem TOO crucial to get the right one.
Take apart a ball point clicky pen, and stretch the spring ever so slightly bit, make it 10% longer, and use that.
b
bd1308
Sep 13 2006, 10:23 PM
I think that spring helps to keep the dizzy drive from chattering between the gear drive and the dizzy body.
b
