So I am driving home tonight from work. Its dark and I have the lights on. I pull out of the parking garage to the intersection that leads to the on-ramp. In LA traffic, that takes 5 minutes.
Anyway, I am sitting at the intersection, waiting to make a left with my left turn directional on and I notice that on the dash, both direction lights are blinking.
My cold start valve is disconnected and it runs a little rough when cold, so I turned off the directional and rev'd the engine a bit. Click the directional on, no more problem. Hmmmm...
Ok, so I drive the 16 miles, in 45 minutes to get home. The last leg of the trip is about 5 miles and i can go 90 there if I wanted.
I pull off the freeway onto the ramp which leads to a stop light. Left turn again and I notice it happened again!! Same drill, turn off, rev a bit back on, only the left is blinking now.
These seems like an early wanring of something more dire. Since I don't drive much at night, I haven't used the headlights in a while. Not sure if this, plus stereo (nothing fancy, no mega amps or anything) plus the directional is casuing a drain somewhere.
Any and all advice to check this is appreciated.
Thanks,
Joe
